subframe
mattsho1993
SHO owner
albion, new york
i bought a 1995 MTX the subframe in the rear dropped out bolts are intact looks like they came lose i was told it ripped out a gas line and a few wires. what wires would that be sending unit wires or what? and where are the cap nuts for the subframe bolts? and what else do you think could of went with it heater core? any suggestions would be awesome!!! i think for the worst pray for the best lol :) :thankyou:
tompumped
VT
Where in NY are you? I can come take a look at it and give you an idea if you are close and you want me to.
I've never worked on a sho with a dropped subframe, but i'm sure I could fix it. You can check junk yards that you know of for the fuel lines and parts, or post a wanted to buy ad on here. You might need a subframe if it's real rusted where the bushings go through. I should replace mine, but it's still safe.
tompumped
VT
The nut is accesible under the plug. That plug being there means you had the recall done. The washers underneath the bushings probably rusted off. If the car has that much rust I wouldn't waste my time honestly, unless you have nothing else. The previous owner probably didn't maintain the car so you will be looking at spending a lot of money if you want a reliable vehicle.
mattsho1993
SHO owner
albion, new york
i live in albion ill map quest you lol but yeah i just went out and opened the plugs and there arn't any cap nuts or anything so im might go to the hard ware store and find a nut and washer but in front of the holes for bolt there is what looks like a bolt going down from inside out on the passenger side but on the drivers there is none i have a 1993 MTX but the diff pin blew so i bought this one today... it has the '96 brake upgrade so i jumped on it lol i only paid $250 for the car lol
mattsho1993
SHO owner
albion, new york
p.s. i well know the time and money lol i got like 10,000 into my 1993 lol and this new purchase is my 4th SHO lol but if your willing to i doubt you would but id more than love for you to come out
tompumped
VT
10k damn.
I put probably 3 into the one I have now, I bought it in october? last year. I was mad about that, mainly because of the rust, but 10k is a lot.
I dont' know about 5.5 hours, that's far. What's your schedule like next week
mattsho1993
SHO owner
albion, new york
im open all the time i just went and looked at the subframe it looks like the subframe bushings pulled right through the subframe holes so.... i'm just gonna pull everything and put it in my sho.... and keep the other body till i get another tranny lol and subframe.
tompumped
VT
Your open all the time? What does that mean? If you were close i'd probably lend a hand. I never met anyone off here, and I don't really know anyone that works on cars for a hobby or paycheck anymore.
Why wouldn't you just swap transmissions and have the differential welded?
I have to drop my trans soon for a clutch replacement and other work. I'm having the differential welded, because i'd rather worry about the bearings than the diff pin ejecting.
I'm going to try and attack some of the rust also, but I don't know what is the best way. I'll have to research.
mattsho1993
SHO owner
albion, new york
lol i wouldn't say its a hobby but rather a obsession lmao ill have to look into welding the pin. but yeah i tattoo so i make my own schedule lol my next tattoo is gonna be my plenum :) i haven't met anyone on here personally either. im not sure what to do cause i messed with the car last night for ten minutes and got it running lol but the body has no rot lil surface rust but the engine bay like the inner fenders are rotted and my other one the engine bay is beautiful but the rear quarters are rotted and the rocker on one side so idk do you or anyone know if i can replace the inner fenders? i was going through the car and all in all its a nice car the subframe is repairable so i think id rather drive one and put the other one up for major surgery lol my project lol put way more money in it then i already do like i said its an obssesion i fell in love with these cars when i first rode in one :) then i knew id always have one!!!!:omgsho:
