Subframe Connectors
92sho16
b00sted
Liverpool, NY
Subframe Connectors + Plans For H brace ?
Now before i get any flaming i have searched the topic but i have my material now and i have the dimensions but i need to know if anybody knows what angle the cut needs to be?
I have this picture to use http://images.cardomain.com/member_images/4/web/256000-256999/256378_48_full.jpg but it doesnt say what the angle should be. Can anybody help? TIA
*edit* are there any plan for making a h brace or is just something that will have to be frabricated?
twr
whoohoo
half-way there, I think.
Man, that's simple trig - do the math. It's about 5.36 degrees, you'll be fine with 5 degrees plus or minus, or use a framing square to figure it out.
Most fab shops only use angles for reference, it's all about the bevel. Now - the cuts are 5.36 degrees for an overall anlge 10.72 degrees.
92sho16
b00sted
Liverpool, NY
didnt think of that, my bad. hijack on my own thread Are there any plans for making an h brace?
SHOman24v
Fresno
I dont use 5 degrees on my subframe connectors......why not make one cut at 10.7 degrees instead?
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
You still have to make 2 cuts either way, unless you're using 2 separate pieces. Even then, making one cut at 10 degrees and leaving the other square will result in the ends not matching up perfectly - 2 cuts at 5.36 degrees will result in the 2 ends mating perfectly.
SHOman24v
Fresno
How will they not match up correctly, your cutting to pieces of metal strait and then welding them together.
I have plans of making an H-Brace and selling them for maybe $50.00 but i need plans or a master brace........anyone willing to help?
You could get in touch with drivinhard and see if his guy in NY is planning on another run of H-braces.
92sho16
b00sted
Liverpool, NY
I made one cut a 10.7 degrees and the first one fit perfect and the second connector was a tad off but nothing that caused any trouble. I have some 2x2 14 gauge steal already so im going to just cut it up and make it fit, i measure the box to be 5.75 x 9 inchs.
