SHO Subframe differences.
venvo
pleasant praire wi
Hey guys. I have been having an issue with my 13 SHO. I had gotten it with a broken passenger axle. I ended up changing it and the axle was resting on the subframe. So then I went ahead and changed both upper motor mount and trans mount. I then went to change the lower dogbone mount and the front lower mount, but they were going in crooked and not lining up. After struggling with the motor I see that the trans was kissing the frame and seen that the subframe was pushed over. So after changinga ll the mounts Im just gonna go ahead and change the subframe/ engine cradle. My question is what is the difference between the 2013 one and the 2014-2019 mount? I went on car-part and 2013 is the only year that is different. They have it as from 09.04.12 and through 09.03.12. My car was made in 03/12 but would i be able to put one from a 15 or 16 SHO? and whats the diffrence
SnuffyTheSeal
Florida
I may be wrong (others may know more) but newer ones may be missing the ears for the front transmission torque mount. Ford deemed them unnecessary and removed them, but some newer years still had the ears on the frame under the radiator.
hosbaldosho
