Strange Audio Issue
fitefanSHO
Chelmsford, MA
Basically, my audio cuts out and is then gone.
The stock radio works fine, and sound comes out of the speakers in the morning then within an hour or less, what happens is the audio cuts out a little (gets quieter) and then dies, no sound at all for the rest of the day. When this happens, the radio appears to still be working fine, it's on, will change radio stations, the tape turns, etc...just no sound output.
Any ideas?
bigblock
cali
im no audio expert but first thing that comes to mind is the amp.
badcamelot
Utah
no sound
It does sound (no pun) as though you amplified circuit, once hot loses connection. Question is though is it the HU or the amp? You could swap amps with another SHO first and see if theirs fades out, same thing with another HU. Solder connections somewhere are bad, meaning once there is enough heat to soften the remaining connection, it expands and loses connection.
It doesnt seem to be a wiring issue.
Good luck
tnel23
TooMuch
Texas
I am having the same problem, mine started out that sound would only come from either the right side or the left side, then it would work on all speakers, now I have no sound at all. it just stopped yesterday, yes it looks as if all is working just fine, but have no sound what so ever!! I think I am just gonna replace the stero and see what happens!! Ill let ya know if that works for me!! I really hate not having music in the car!!!!
tnel23
TooMuch
Texas
I having same issue
Mine started out that the sound would only come out the right or the left side, then it would work on all speakers all of a sudden, but now I have no sound what so ever, and the stero seems to be working just fine, even when I out a Cd in it shows it is playing it, but I have no sound!! I am gonna just replace the CD player and see if that works!! Ill let ya know!! Good luck!!
tnel23
TooMuch
Texas
Well I finaly replaced the stereo with a aftermarket and it went in easy and was a simple hook ip with harness, but I still have no sound coming out of speakers, and now my dash lights won't turn off, anyone wiht any sugestions please help!!!
tnel23
TooMuch
Texas
Wher is the AMP located in the car, because I did not replace that part, but I have no clue to where it is! I ahave a 1992 MTX that had a cd and tape player, that i removed and put in aftermarket hoping it was the stock stereo!1 Any suggestions will help!!
kikkinasphalt
Wrrrrrrrr
Missouri
the amp is in the trunk, bolted to the rear seat.
sounds like its overheating to me
thatSHOguy101
