Spun rod bearing in 93 MTX
Blackdr16
93 SHO
Washington, Illinois
I just rebuilt a 3.2 SHO engine (new rings, main and rod bearings) stuck it in my MTX car, drove 600 miles and rod bearing spun on no.4 cylinder. Im sure my crank is damaged as the piston started hitting the head. Is the crank in my 3.0 engine the same as the 3.2? If so, i guess ill pull motor and swap cranks. Prob have to get new rod also, same in the 3.0 versus 3.2? I know piston diameter different, but not sure about the other two. Thanks....appreciate any response:thankyou:
CademiaX
What's an SHO?
Utah
Don't you have to balance the engine if you swap out the crank?
llamaking122
Green Machine
Columbus, Ohio
thay have for like 50 on ebay plus ship its a sho seller on there there user id is Super_high_output i trust someone with a name like that lol just thought i would help:nut:
shobroooo
