Ok, so after an afternoon of wrenching, and snapping stuff, I come to realize, every nut has red locktite all in them. ****, I couldn't even break the o2 sensors loose.
So, blow torch it is, I guess? Is this normal?
PS...thanks, guys! It is the correct pipes, got it sorted. But good god, getting the OE stuff out is busting my balls...bad. Suspension was a cake walk compared to this.
https://shoforum.com/index.php?threads/engine-swap-13-into-a-10.138777/#post-1502940Will a 2013 + fit in my car What complications would there be? So how much of a difference is between 2012 and 2013 engine block?
Well I talked to them on the phone again today sounds like nobody knows what the **** they're doing over there at that shop. I'll find out at the end of the day if I get a refund for a new motor so on that note anybody know where I can pick up a new reman long block for our cars cuz I've been looking around and I can't find shit.
This is a pretty good thread on what all has to change, but it's definitely doable.
https://shoforum.com/index.php?threads/2010-to-2015-sho-engine-swap.131474/
Outside of the struggle to get the broke stud out, you can get new studs and nuts for them. Which in hindsight, probably isn’t a bad idea.So...quick question...
On the upper part of the DPs...the triangular ****** end...which typically mates to the header...what happens if one of those bolts/studs snap off while trying to remove the nut?
Hasn't happened, and I'm done for the day...next day off I will hit them with a torch, then splash water on them...
But...what if they do snap? What's the (likely heinous) process to fix/replace those?
I love peanut butterPB Blaster is your friend.
Moved my old flooring out in the new LVP boxes. 15 boxes fit with room for more.View attachment 15293
Trying to install intercooler.
Getting stuck on stupid things. Had to buy new hose clamp pliers for lower radiator hose. Now fighting with plastic clips on fan wiring harness. That 15 minute installation video where everything goes smoothly makes me feel ********.
I bought a bunch of the push clips from Ford after I installed mine.Trying to install intercooler.
