Zpak
Es Aich Oh!
The region, Indiana
Absolutely, after seeing how little came out, I figured I could just flush it a little at a time. Honestly, aside from getting the plug back in, it wasn't bad.
I'm nervous about tapping a drain plug. I've no idea what the inside looks like. Where to drill, etc. Lots of ways that could go wrong.
Yes it was a scary thing to drill a hole in a critical case of fluid but it really was not a big deal at all. I just did it a few weeks ago. And like you said, getting the plug back in was still really the hardest part. You do have to remove at least the front turbo downpipe.
skyshadow07
Oklahoma
I went to the track for the first time this year, ran a 12.92. It was so damn crowded that I only got to run 3 times.
IMG 20200501 204344
Get that sixty down as you are a 12.5 car.
Best sixty for me is a 1.77. Stock everything, with Conti's. 26 psi in the front, 40 in the rear. Advance Trac off, around the water box.
skyshadow07
Oklahoma
I definitely feel like I did not launch perfectly at all. Plus with the long waits, our damn intercoolers heat soak just sitting turned off.
StealBlueSho
NA
New shoes! Enkei 20x8.5 +40mm offset with 255/45/20 Continental Extreme Contact DWS 06.
Got the 4 wheels and Blizzak tires for $350, got the Conti’s installed for $900.
Had them mount and balance the Blizzaks onto the stock flower wheels for future winter driving.
5b602c3c0a412b4d14baa2a28e39b9ce
6ca51932edeae47e261db42b585e6adc
A26f5ad3d908eb70003228e9aaad5cf4
78853c91d8073a4573fded372d22bc63
222dd281d7f4439b516781556f73b18e
68370b945af5d3119a53e262664f1b89
0d9ae92be2241d999fbf71a253cd87e9
C51759ef3afe4fff4259bab68438eaee
Mike....26 psi in the front and 40 in the rear....
Give her a good launch and please report back.
StealBlueSho
NA
Looks good! How did you get the conti’s so cheep?
VA Tire in Gainesville VA readjusted their prices to be competitive online... when they told the per tire price ($192) I asked them to double check the sizing.. but it was what it was.
This combo shaves 8.15lbs per corner in rotating weight which is significant PLUS over a half inch of additional tread contact per tire. Should see a drastic improvement in my 1/4 mile times.
Kevin81
USA
Today, I set about to flush the trans, only to ask myself...WTF? Where is the fill port for it? Now mind you, I've never owned an automatic car...but...I'm pretty sure there is supposed to be a spot not unlike to oil port, right in the engine bay. Had to Google that shit. The ford engineers put it under the air box! Well, after checking, the level is good, and its clear and pink. So, again, I'm like, I guess I'll leave it in. I'll keep an eye on it, and now I have a case of motor craft mercon lv, for when I DO need to change it. Easy peasy. But, then...I got bitten by the dreaded "while I'm at it" bug. Decided to get a look at this intercooler everyone is talking about.0502201449
Had oil gunned on the underside of the piping...uh, not good.
Also, dumb question...but the plastic thing on the upper left side of that pipe...what is that? The BOV? Made from plastic?!?
Kevin81
USA
So, I yanked that Crap off.
0502201536a 0502201537 0502201536
Pretty clean plenum...but...leaves in my engine bay!?! This is the evil of engine covers.
Down the deep dark hole my vacuum hose went. I got about 3 oz of some really nasty black stuff out, with the driver side of the car elevated. I don't have an air compressor, but one of these days, I'm going to have to get one...with proper suction, I think this method would be more effective.
Kevin81
USA
And last, I painted my calipers. Red, of course. I used the kit that is painted on with a brush, but its better to just remove them and paint them with a rattle can. I will likely be swapping out for aluminum willwoods before I bother yanking the calipers off, though...0502201601a 0502201308 0502201431 0502201308a 0502201601b
Stick a fork in me, I'm done for a couple weeks, lol.
Kevin81
USA
Also.,.I don't want to alarm anyone...but has anyone noticed? The ford engineers put that V6 in there...the WRONG WAY!
Today, I set about to flush the trans, only to ask myself...WTF? Where is the fill port for it? Now mind you, I've never owned an automatic car...but...I'm pretty sure there is supposed to be a spot not unlike to oil port, right in the engine bay. Had to Google that shit. The ford engineers put it under the air box! Well, after checking, the level is good, and its clear and pink. So, again, I'm like, I guess I'll leave it in. I'll keep an eye on it, and now I have a case of motor craft mercon lv, for when I DO need to change it. Easy peasy. But, then...I got bitten by the dreaded "while I'm at it" bug. Decided to get a look at this intercooler everyone is talking about.View attachment 13010
That is the noisemaker. It literally is supposed to enhance the engine sound in the cabin. It is known to leak boost. EPP has a nice set up to eliminate that.
Zpak
Es Aich Oh!
The region, Indiana
While we’re on the subject. Our trans doesn’t have a serviceable filter so the ol’ drain and fill is still a good idea to do on a regular.
markmoomnu
