Magna
Removed the snow tires yesterday and back to Summers. Looks 100 times better lol
BoostfoSHO
Drianed my Catch can that I recently got, probably 2k miles. I think I need to do it sooner maybe every 1k. Love the drain hose. I don't even have to remove the can. It seems like it's alot so I checked my oil level still looks good. I'll inspect the turbos next time im under the car. Ebc9ae800c30f90a7efb6d3be2df0b76Af2355cc4c01ccc26a007700adb5904a
Sent from my Moto Z (2) using Tapatalk
Bronco2fan
Texas
Those really do look nice. Wish I had the guts to mount something like those too. Good job.
sanman
I should have asked....does that speaker grill just pop off?
Yup pops right off there is a clip basically in each corner. I also bought a spare cover on ebay just in case i sell the car i want to keep the gauges... A picture of the clipsCover
sanman
Real easy if you want i can tell you how then buy a spare grill cover to replace when done.. AeroForce gives you pretty detailed instructions on the drilling to run the wires..
Matt M PA
Thanks for the info! I installed a pair of these in a friend's Challenger a few years ago. His only complaint...if you could call it a complaint was that they didn't dim when the dash lights went on. Maybe that's fixed by now...
'14SHO
Chemical guys detail spray (now available at my local Walmart) in between baths. Beautiful weather so she’s getting her legs stretched tonight.
TomahawkSHO
Changed engine oil, PTU fluid and RDU fluid. Rotated the tires. Painted the calipers. I was kind of ticked off after doing the PTU. I was lucky if I got out 1 oz of old fluid. Used two different size hoses on my suction pump but to no avail, so I figured I would fill it and see how much was in there. Well to my surprise it took 14oz of fluid before it started to seep out of the hole which tells me I had only had around 4 oz in there vs the 18 required. I have had a harmonic vibration between 40 and 45 for awhile, after changing the fluid and rotating the tires I thought it would go away. Well it didn't. I have a sickening feeling I'm heading for a PTU failure. Needless to say it will be visiting the dealer since I only have 37k on it. On a side note the little bit of fluid I did get out was actually pretty clean and the magnet looked decent. RDU was a tad low, sucked it out and was able to get 32ish ounces back in.
Where'd you get/make your emblem overlay?
markathome
2010 SHO
VA
Ordered new roof moulding strips as the old ones were rooting away.
Sent from my XT1094 using Tapatalk
xFallenxCripplex
Put the car on a lift to get lots of pictures underneath and found after putting amsoil 0w30 oil in start of winter now I have a oil leak
A co worker said the bolts in this area was loose on his but I'm taking it back to forr for them to document it but hope there not going to blame the oil.
Super slow leak or maybe some how it's from before the oil change the oil is still full.
https://goo.gl/photos/XGCeHsZFxjgm1MB46Fbed0862c79b8772333ca95d4b92223b1cdd0e52d1cc19c9ff8831dd58f6d1786feb25faa682c44e09f2041ea08cedfc
Sent from my Pixel 2 XL using Tapatalk
markmoomnu
