Off Road SHO
Moderator
Zack,
Why is it that you don't want to run the stock SHO computer?
Tom
Tom
Well, got some bad news.
I was having my heads reworked; valve job and seals, nothing major, just to prevent any blue smoke on start up.
On the rear journal of the left head (if facing the crank pulley) outboard cam there is some considerable bore damage and galling. Talking it over with the machinist, we agree that it was oil starvation caused by a fully or partially plugged up oil passage.
Strangely, the cam journal looks ok. Since this is my "proof of concept" motor and only needs to last me a relatively short time, I told the guy to just do what he could with the valves and guides, don't worry about decking them (they are off by 0.004") and I'll run with them for now.
SO...anyone seen this happen? The mains and rods looked great and so do the rest of the cam journals, but this one rear outboard journal is about a 5 on a scale of 10.
What I was going to do is lay a bunch of molybdenum disulphide powder in to that specific cam journal and hope for the best for a few thousand miles. The oil passage has been cleaned out and oil should fairly freely flow to that journal now.
Comments? Keep in mind, this isn't the performance motor that I have planned, this is the motor I am going to use to get back and forth to the grocery store and run errands with while I build the performance 3.2 motor. This will get the car on the road and allow me to make the custom parts I need to make the swap work and get major electronic bugs worked out.
I guess what I am asking is, do you guys think my cam is going to snap in half a few minutes after I start the car? Anyone seen this happen? What are the consequences of this kind of damage in this motor?
Thanks,
Zach'sV6
Unfortunately, "considerable bore damage and galling" is kind of a subjective description. Got any pics?
That said, any damage to the cam bore is a new one for me, although granted I'm not exactly a guru (yet). Before this, I've never heard of any sort of cam oiling issue or cam damage in a stock SHO V6, ever.
If the cam itself was undamaged after living in that damaged bore, I don't think there's any reason to believe that it would be damaged when it's put back and run that way, especially since you've made sure the oil passage is clear now. Was the oil passage there indeed plugged?
Worst-case scenario, if the cam does warp or break or something, you could just replace the head (or you could just replace it now). It's not uncommon to see used heads with cams going for less than $100 around here or on eBay.
Since you mentioned it .... when you do get around to building a "performance" motor, deck the heads by taking off the least amount as possible. The way the cam tensioner works, it causes cam timing issues once the heads are decked. IIRC, my race engine heads were decked ~0.004" and there is a difference between the banks. I really need to install a set of adjustable cam sprockets. All my datalogs shows slight difference in the 2 banks (~3% fueling).
I have a 1930 ford speedster and am running a 3.0 SHO/ T-5 combo. I made the bell from an old blown up trans-axle. Use the bell part, weld on a 1-1/4" plate to the stock case surface. Then turn the center register hole. plug in a T-5 to transfer the hole pattern. Have the bell side lightly surfaced, then the plate side to get your finished thickness. Done.
I use a stock SHO t/o bearing with a few thousanths turned off the T-5 candle.
The throwout arm is cut/bent/welded 45 degrees and an anchor made to use a 1979 Pinto cable.
I might have used a Mazda or Windstar bell/trans if I had known back then....LOL
Sorry pic. exceeds forum size...
I have a 1930 ford speedster and am running a 3.0 SHO/ T-5 combo...
