Dan Palmer
Has anyone had any problems with their motor running rich after a cam failure? Have put about 600 miles on motor since I had it repaired and I am at a loss.
You are going to have to get your codes pulled before you can really narrow it down to a specific symptom. AutoZone scans codes for free in most areas.Craig Van Buren
Member # 2863 posted February 26, 2004 10:39 PM
I don't know if I am having the same problem or not , but after my cam faliure the "Service Enging Soon" light came one. Literaly the day after I got it back from the dealership. Can anyone tell me if it's this, or a faulty O2 sensor or anything else that sounds like this. Thanks in advance.
Craig
Yea I thought the same thing I used to run a cold air intake in my ranger all winter and it ran fine, then when I had the bad o2 sensors in my SHO, my mechanic told me that I shouldn't be running the cold air intake in the winter. I've alsoo heard from other people who have cold air intakes that some run them in the winter and some don't. So I dont know who to belive. their must be some mechanics out their that are telling people not to run the CAI in the winter. Who knowsMr. SHO:
I don't know why you would run without an IAT in the intake airstream. I run a CAI with a cone filter in the bottom of the fender, but my IAT is still operational. It is located just upstream of the MAF. I would think it would be better to physically remove the IAT by unplugging the electrical lead than to just have it sitting in your engine bay, thinking your car is getting a hot air charge. Remember, the IAT is integral in adjusting your engine's timing advance. I don't see why anyone would want their car to run less timing advance with a cold air charge. shrug
SHOwallen, your mechanic is dead wrong.I would stop taking my car there from now on if I were you.
If the O2 sensors were replaced and that did not do anything, then chances are you do have a problem. Like a sticking injector or something. How is your gas mileage?spragers:
I have been getting running rich codes on both banks since I bought my car used two summers ago. Ford said it was an O2 sensor, replaced one, didn't change a thing. A local garage, and Performance Plus in Madison, both said they could not find a cause of the problem, and that until it really has problems running, I shouldn't worry about it. Glad I bought my own code scanner, at least I can clear the codes whenever they pop up!
I think the only reason why you wouldn't run a CAI in the winter is b/c of the increased precipitation, road salt, etc. that the filter might be exposed to. I have a splash shield on my cone filter, and after several months of abuse, including encounters with several puddles over one foot deep eek! , the filter is none the worse for wear.SHOwallen:
But I want to put mine back in I love the sound when the secondaires open up.
