rod bearings?
madsho
madison,wi
how difficult is it to change the rod bearings... mind you i am a beginer when it comes to the do it yourself stuff... and does chilton's or hayes make a repair manual for the sho
93rev2sev
Hockeytown
Rod bearings themselves are not that hard. Replacing your exhaust ****** studs will be the chore. Since you are in Wisconsin, you will be lucky to get your y-pipe out without breaking the exhaust ****** studs. I was lucky to have the back 2 studs remain intact....but...still had to replace them because the threads were totally corroded off. do a search for exhaust ****** studs to find out more...Don't let a shop do the exhaust studs...they will want to remove the manifold...that's no no(more broken studs than you started with). And don't waste time and energy with heat...just drill those suckers out and retap.
This is the only thing that I would be weary about. If you get your y-pipe off without ruining your exhaust ****** studs...you are home free.
If you have to replace one stud...might as well replace all of them...with stainless.
Use the Black RTV that comes with the rod bearing kit from RCM automotive. Apply a smallish bead of silicone in the prescribed places mentioned in the tutorial here:
http://www.shophoenixproject.com/rodbearings/rodbearings.htm
Just dont gobb the RTV...when it hardens it will break loose and clog the oil pickup screen.
For cleaning the oilpan/pickup tube/inspection cover/oil baffle/windage tray; I used a kittly litter tray filled with about an inch of kerosene and a strong brush. Clean all the gunk off of the parts and hardware, run the kerosene through a paint strainer and reuse it to get the parts real clean. Then rince with Gasoline and let the oilpan air dry upside down - on a rag. Use acetone on a scotchbrite pad or paper towel to clean all the gasket mating surfaces to ensure a good seal.
Don't remove the oil level sensor unless it was leaking or you have a new one and a gasket...just cut the wire and use a bullet type connector to reconnect it during reassembly.
Hope this helps.
Follow the http://www.shophoenixproject.com/rodbearings/rodbearings.htm tutorial and you will be fine...
Just make sure you have a reliable torque wrench before starting.
dantheman68
Kinda Big deal
Pewaukee, Wisconsin
x 2 to the RCM idea....
theyre not hard, you just have to be careful, one mistake could cause huge problems... but theyre hard mistakes to make unless youre careless/lazy and don't know how things went, dont scratch the crank when youre pushing the piston up, and make sure the mark on the rod cap is facing the front of the motor! torque the caps down corrrectly as well as the oil pickup tube :thumb: if youre a new SHO owner... a good 3/8" torque wrench is a VERY valuble tool (i got a clicking one for like $20), well it was for me atleast, and youre definately gonna want one for the RB's
Elton
Holiday, FL
Rod bearings were actually a lot easier than I had thought. I followed the instructions from shoproject.com and they were great and made the job go quickly. I actually just finished doing mine yesterday and I think it may have taken me a total of 4 hours start to finish, including time away to look at the computer. I had to modify one bearing though. It seems someone had spun a bearing before, and had thrown a new bearing on to sell it. I never knew. So I had to get one oversized bearing and resize it. The rest were standard sized. Now the motor runs smoother than it ever had. But follow the instructions, they work.
RacingNotPacing
Lawrence, KS
I havent done this on my SHO yet, but when i put motors together I always put fuel line or vacum line peices over the threads, that way when the rod is pushed up pass the crank the threads wont scratch. Its just some good cheep insurance!:thumb:
dantheman68
Kinda Big deal
Pewaukee, Wisconsin
yeap i was gonna say that too... check the clearances too!! Elton just proved how important that is!
i got lucky by only checking a few of them... i know they were never changed before... pretty good maintenece records :thumb:
