Yamaha V6 said:No, Clevite sells multiple sizes of the SHO Rod Bearings, all based off the root part number (CB1435P), with an optional oversize identifier (+.25mm / +.50mm / +.75mm, or inch equiv. +.010/+.020/+.030).
Yamaha V6 said:My 91's were +.25mm, Chris Benvie's original blown motor as received was +.75mm!!! (WHO in their right mind builds a supercharged SHO motor with a turned .030" crankshaft???)
Can you get a pretty good idea of the rod bearing condition by checking oil pressure?Yamaha V6 said:Murph, I have been touting Rod Bearing Swaps for well over a year (was actually accused by SHO Shop of making it up as a money making idea!). If you lose a Crank Sensor, you need a tow. You lose a bearing, chances are, you need an engine.
Does everyone need rod bearings? NO. Can you be sure you don't until you take the time to tear it apart & look? NO.
At which point, if you're staring them in the face, you may as well change them. It takes about as long to do bearings as it does to do a 60k, and the parts are a LOT cheaper too. The down side to rod bearings vs 60k is, you usually notice a performance re-gain after a 60k, and you won't after bearings.
I also came to this conclusion myself which is why replacing the rod bearings was the first "major" maintenance item that I did on my SHO, within a month of me buying it, before I did any 60K work. I wanted to take a peek at things down there to make sure my SHO was worth the amount time, effort and expense that I was willing to put into it. Fortunately, everything passed scrutiny and now I have tremendous peace of mind with those new bearings in there.SHOMurph said:If you car has over 150k its a good idea to change your rod bearings. So many motors are going down now with spun bearings.
This might need to become the first maintainance done to every SHO now. Its more important than a 60k.
But they still call them undersized bearings as they refer to the size of the crankYamaha V6 said:No, if the crank is UNDERSIZED the bearings that make up the difference would be... OVERSIZED, no?
a) unless he's the original owner, there's always that possibility that the engine's been rebuilt, which is why I left it open.
b) with the variances I've seen in cams, shim ranges used to gap correctly from the factory, I wouldn't be surprised to see "Friday" engines with re-turned cranks. Not saying it's true, but I wouldn't be surprised.
You know, I can never keep it straight what they call them. But it's not too hard to figure out that a reground crank in going to have smaller than stock journals (ie. undersized) and the bearings are going to have to be thicker than stock to make up the difference (ie. oversized).yamahaSHO said:But they still call them undersized bearings as they refer to the size of the crank![]()
