removing wheel bearing race.
pete c
ellington, ct
I am in the middle of replacing my front driver's side wheel bearing. Got the snap ring out, and after much beating, swearing, chiseling, heating and further swearing, I have managed to get the guts of the bearing out. Unfortunately, these guts were about the only thing you can beat on. The outter race does not really provide a good point to push on. I am guessing that the only way to get the damn thing out will be to cut/chisel it. Unfortunately, I don't have anything small enough that can fit in there. A dremel with a right angle attachment would probably do the yob. I don't have one, unfortunately. I tried a hacksaw blade on it, but the hardened race just laughs at it.
Any suggestions other than the obligatory "time for a 96 brake upgrade"?
shopartsnw
SHO Medic
Sponsoring Vendor
Battle Ground, WA
I grew up beating the wheel bearings out with a hammer, but on a SHO you really need to use a press. I use a cheap 20 ton pressfrom Harbor Freight, and even that won't get all the bearings all the time.
Even if you can get the bearing out, you will need a press to put the new one in without damaging it.
Before I had a press, I would just take the knuckles to the local tire shop. The would press both bearings out/in for about $30-50
- Mike
pjtoledo
'ol man in the SHO
toledo,ohio,usa
It can be done, but it ain't easy. You may want to consider a replacement spindle. I took a chunk of about 3/8" plate and turned it down so it would fit past the outer ring of the spindle but not the inside narrow part of the race. Then I put something big in the center and beat on it, for hours. That "flat" piece of steel now looks like a cupped washer, but I got the race out!
Perry
shojuan
sunny San Juan Bautista,
Once the machine shop I took my knuckles to had to weld a piece of rod or some such metal to the remains of the bearing so he could press it out. This was after spending a lot of time trying to get it out. I forget if he broke some sockets in the process. Sometimes they come out harder, sometimes easier.
Doesn't look good for my cheap $110 12 ton harbor freight press I just got. That's a step down from Mike's. I wanted the 20 ton which was on sale for $180 when I got the 12 ton but the boxes were just too big and heavy plus I would have had to swap my car for a truck to get them back home. I'm thinking about swapping out the 12 ton bottle jack in mine for a 20 ton air powered jack but that won't change the fact that the frame on the press is less beefy than the proper 20 ton unit. I suppose I could always weld in some extra metal...
The $45 a knuckle average that machine shops charge to R&R bearings from your knuckles is money well spent. Drop 'em off, pick 'em up, fork over some cash. The only cussing is at the ATM machine.
shojuan
Sounds like you need to weld some metal to the outer race. A good machine shop should be able to do that for you if you don't have a decent welder + enough basic skill to make a solid joint and not mess up your knuckle in the process. I wasn't charged extra years ago when my machine shop had to do this. And that's after he spent a lot of extra time trying to get it out the "usual" way. If he knew what he had to do right off the bat it wouldn't have taken very long.
pjtoledo
'ol man in the SHO
toledo,ohio,usa
Who needs a press???? I can replace front wheel bearings in the basement with about 10 pounds of "special" tools. Total cost less than $30. It's a bit awkward, but I can do them with the spindle still on the car too.
Perry
