With a flashlight shining down near the area between my PS pump and serpentine belt tensioner assembly, I can see a small puddle of PS fluid to the right of my PS pump, between the pump itself and the serpentine belt tensioner assembly. I'm surprised it doesn't just drop to the ground, but there must be some sort of surface there (maybe on the bracket that the tensioner puller bolts to?) that allows it to collect.
So.....
What's most likely to be the source of the leak on a PS pump?:
1) The rubber hose hear the top
2) The copper fitting and neoprene o-ring gasket on the left
3) The pump itself.
Let me clarify that this is not a motorcraft pump, but a rebuilt cardone, which kind of makes me wonder if the pump itself is leaking, but I doubt it.
I'm inclined to think it's the o-ring/copper fitting.
Even though the o-ring is on the left side of the pump, and the puddle is on the right, it could be leaking down the left side of the pump, then UNDER the pump toward the right.
I guess the rack could leak too, but I think it's too high up to be the rack.
Has anybody ever had a leaking PS pump before that could offer some insight? I'll drink another beer and hope somebody reads this!
So.....
3) The pump itself.
