Paint color and good source of paint online
Devin
3.Slow
Pacific Northwest
I have a spare decklid in my garage that will be binned if I don't get it on my car soon. I want to repaint it from white to Light Titanium to match my '90. The paint code on the door shows FC4, but when I search I just come up with code YF when associated with 90 era Fords. I guess I could just buy a pen and see if it matches, but I'd rather get a quart or so at once so I can spray it.
Any suggestions on what the proper paint code is and a solid vendor to buy from?
Irish Pride
Irish Inside
MusicCityUSA
Direct from the source, the Ford parts catalog. Paint code is YF. I have never seen a Ford paint code be more than 2 digits. Something is up with your decal or you are looking at the wrong thing.
Go to an O'Reillys that has a paint department and have them mix it for you. You can get it in an aerosol can or by the quart. If your local O'Reillys doesn't have a paint department, have them get a transfer from one that does.
20210521 170826
Devin
3.Slow
Pacific Northwest
I see it now. It is a wierd spot. I thought it was under body, but it is above.
20210521 183339
Thanks for the tip on O'Reilly, I'll check them out.
I have had the best luck the automotivetouchup.com - you can get it in a rattle can or a bottle/can of different sizes depending on your needs and the color match is great and the quality seems very good.
Devin
3.Slow
Pacific Northwest
I looked and I can't tell if there is an O'Reilly's in-state that does color but I'll call them. I'll check out automotivetouchup as well.
Thanks for the suggestions! I just had to move the deck lid outside so the clock is ticking.
Jbeck
I have NO IDEA what I'm doing!!
Houston, TX
Hey man if you need a reproduction door decal, I can reproduce them...I have already done a few for others and one for my car as well...let me know.
Irish Pride
Irish Inside
MusicCityUSA
I'm gonna be sending you another one for my 95.
-Chad
Jbeck
Houston, TX
-Chad
I am glad you are happy with the one for your 90 I did...eventually I want to have a complete data base of all the decals for the whole car....I need some more images to do that. I need to get a hold of the other door tags...there is on on each of the back doors I believe for the child lock operations that I need and also the one on the pass rear fender well inside door jam that has the vehicle weight and tire size info on it....one step at a time though.
just send me what you need and I will get it done for you
