Doing my rod bearings this week. I ordered the bearings. Where can i get the oil pan gasket? Or is it the seals that napa list? Do i need any other parts? Also what did you use to **** the bearings when installing them? thats for the help
If you want a new P/U gasket, you can get the Fel-Pro TCS45871 set which includes another front pan seal, pickup seal and an ill-fitting front main seal.SHOoff89:
What about the pick-up tube gasket? Are you going to reuse the one you have or make a new one? Does the Fel-pro kit include this? I just bought the Fel-pro oil pan gasket set, and it didn't have it, but the Front Seal set I purchased last month for my 60k did. Is there any one kit that includes all gaskets needed for the rod bearing change?
Verify the pulley diameter first-hand. Vadim used to sell the 15psi pulley with both the 9psi & 12 psi kits, to spool the boost up faster. He then used 2 different air restriction methods for 9psi (small air filter) & 12 psi (metal reducer sleeve in-line). I found this out the hard way 2 1/2 years ago when I ordered the 12 psi pulley from SHO Shop (paid for it & overnigth shipping), and got the exact same pulley I had, then I ordered one direct from Vortech, overnighted, to discover the same pulley again.midospike:
Thanks guys. order the bearing today. Going to autozone to get the gasket. With new bearings and and 120k work, i think i am ready to put the 12lb pully on the supercharger or not. LOL let see what happens after i get done with all the work. thumb
The Ford EGR tube gasket fits and can be used in place of the discontinued picup tube gasket (per Josh a SHONut)Rockledge:
The Fel-Pro oil pan gasket kit does not come with the oil pickup tube gasket. Can't get one from Ford, either (discontinued).
Following the advice of others on this board, I made my own gasket out of gasket material I purchased from Napa. I was able to match up the gasket material (and thickness) very well, and then just cut it out to fit.
You have to hog out the center hole a bit (and maybe the bolt holes, I forget) and it's hard not to damage the graphite material on those gaskets while you are doing that. Much easier to cut your own gasket. Also I don't like the thickness and characteristics of that EGR gasket for the pickup tube. That EGR gasket really wants more torque to squish down good than you can safely supply with the pickup tube nuts without stripping the studs. At least that's just the way it seemed when I was debating whether to use one after I hogged out the holes.jelloslug:
