oil light flickering
sho_u
port vue, pa
my oil light flickers a little then quits.
only when i pull into my parking space
(a little on a slanted hill).
its at max capacity for oil level.
are 94 atx 3.2's known for oil pump failure or do you think my sending unit is going bad???
thanks bryan
noSHO
ohio is for hustlers
The oil pressure sensor is probably going bad. I'd have it checked out (or do it yourself), but mine went bad. I made the mistake of panicing and rushing out and buying a 3.2L engine. Turns out all it was was a faulty sensor, so now I've had a 3.2L sitting in my garage for like 2 years. Oil capacity and pressure are entirely unrelated. You can have full oil level and low oil pressure, as well as being 2 quarts down with perfectly fine oil pressure. You'd think the two are related, but they really aren't. The first place to start is have your sensor looked at. After that, if it's determined to be good, get a mechanical oil pressure gauge on the car. You can get a Sunpro one for like 20 bucks or less at your local auto parts store.
rangerj
Brunswick, Ohio
Check your oil sending unit. It is on the firewall side of the block closer to the driver side than the passanger side. Check for any oil arround the switch. If there is any oil the switch is leaking and needs to be replaced.
Check the connection. If it is corroded, clean the connection. rangerj
noSHO
rangerj:
rangerj, you're from Brunswick? I didn't know that! Have we met before? I'm from Mentor (at school in Athens right now).
Bizzy
Dave, Jack was sitting right across the table from you and Shannon at our last meet at QS&L. He was sitting between Joe and me. We understood though, you were busy chatting with Mark about OTS. wink
rangerj
Brunswick, Ohio
Some further explanation:
The oil sending unit, not to be confused with the oil sensor, is a "ground switch". It is tapped into the oil supply port in the engine block. When the switch is under pressure the circuit for the light in your dash is broken, that is the ground is not connected. Ergo, the light is out.
If the oil pressure drops below a predetermined point the switch is allowed to make contact, and thus ground the circuit. The light goes on.
To test the circuit simply put the ingnition switch in the on position (KOEO). The light should light up because the engine is not running, and oil pressure is zero.
If the light fails to go on you have either a burnt out bulb, a bad connection, or a wire problem (broken, shorted, disconnected, corroded, etc).
If the light goes on while you are running the engine (KOEO,)then you either have very low oil pressure, a failed switch, or a grounded circuit. If there is even a drop of oil on the switch ("sending unit") it is leaking and should be replaced. (Unless the oil has leaked onto it from a leaking valve cover, but then you should see a trail of oil from above the switch)
The most common failures are 1. the bulb burned out, 2. leaking or failed switch, 3. the wire to the sending unit has becone disconnected, has a poor connection, or has been rubbed through and grounded.
Dave,
Yes I'm from Brunswick, and yes, we have met as Bizzy has stated. I think you were distracted by one of the young ladies sitting near you. Bizzy maybe? naughty shrug rangerj
The investment you make at OU will pay you dividends for the rest of your life. "Spend" your time wisely. :cool:
Bizzy
lol...not me. Probably fair Shannon. wink
noSHO
Hahaha...im such an idiot. I remember that, but I never caught your forum name. I was still trying to figure it out like 2 days after the fact. That's my roommate/ex-gf naughty (I don't really like to say ex-gf anymore because it's been over a year now). We're still real close, though. OU actually made an investment in ME, so I've most definitely put their money and my time to good use. I'll miss the school when I graduate here in 3 months. :cool:
tinkerkathleen
