Oil filter suggestions
Sgtmeatsauce1
2013 SHO +pp
New Jersey
I am looking for suggestions on a quality oil filter for my car. I am not looking for a war, just some suggestions specifically for a hard run SHO Ecoboost twin turbo tuned vehicle. I have decided on Castrol 5w-30 Magnatec with 5000 mile change interval. My manual highly recommended the MC FL500S, not because of better filtration but because the EcoBoost motor is sensitive to oil filter, non fl500s filters can cause hard or slow cold starts, start up noises and ticks. I believe it has something to do with the "relief valve" and not the filtration. Regardless I want the best this list suggests for my car. Thanks for any help or suggestions
sholxgt
There are several good filters out there (Amsoil, K&N, Mobil 1, Bosch Distance Plus, Fram Ultra Synthetic) but as you pointed out, the motor was designed with the MC FL500s in mind. The anti-drain back valve on the MC filter is perfect to keep the timing chain tensioners pressurized.
Even though there are filters with better filtration media, IMO there are none safer than just sticking with the MC filter.
Stay away from the Fram oil filters.
Do a search - there is a thread I posted with Ford engineering oil filter test results.
