No interior lights or keyless entry 93 ATX
Jayson_at_IGF
Mountain Home, AR
I recently lost my interior lights and keyless entry functions on my 93ATX. I checked all my fuses and cant find any burnt ones. I even tried moving them around to see if maybe they just didnt look burnt.
Dash lights work fine. I cant think of anything else that is not working.
Are there any connections I can check out?
Sometimes my kids like to use the keypad to open the door. I dont think it could disable the interior lights, but I suppose that is a possibility.
Any help would be appreciated.
Thanks
Jayson
Mr Anonymous
Tire Wall
Sounds like a harness problem under the package tray (in the trunk where the speakers are mounted) where the keyless entry and illuminated entry modules are. I'd check to make sure one of the connectors didn't work loose, or a wire or ground isn't disconnected.
Jayson_at_IGF
Mountain Home, AR
Just FYI in case anyone in the future has this problem.
Checked and double checked my connections with no luck.
Turns out the keyless entry module in the trunk was the problem. I replaced it and everything is working fine again. Different code now for the keypad, but I can live with that.
poffffd
