No heat
ranger690
Wisconsin
So I went to go to work this morning in about 17 degree weather and let the sho warm up for about 10 minutes. Figured it would be fine. Got in and went down the road and no heat, my engine warmed up fine but my windshield fogged up and I couldnt see good thing for a spare car so wat do I do now. I thought I smelt sometyhing funny when the heat was on before, but I checked the antifreeze and it was there so I am at a loss.
Please help
Sounds like the heater core has sprung a leak. Other possibilities include the blend door being stuck in the cold position and not allowing the heated air to circulate.
ranger690
Wisconsin
how do I find the leak where would it or might it be. or can I add more of something to make it go again. Also The blower wasnt working it had one level low the high blower wont work.
If the heater core is leaking, you will see a puddle of coolant either in the car or under the car - you said the windows fogged up, that is a symptom of a leak, although its been cold where you are so its possible that the windows fogged up just from the breath of the passengers.
If the blower won't run, then you won't get much cabin heat even if the heater is working properly otherwise, so you need to fix that first - likely the blower control is bad. pm me if you want one, I have one in my for sale ad for a 92-95 car.
ranger690
Wisconsin
Well I got home after work it warmed up to20 and when I turned it on the blower and heat both worked I hadn't driven for a week so I should drive it more
Thanks for the help
probably just another sho quirk
shobote
Naperville, IL
If you notice the sweet smell of ehtlylene glyciol inside the car, and the fog on the wiondows is still there, it is due to a slight leak in the heaeter core or a line near it is leaking. You dont want to drive around like that very long, as the fumes are a health hazard.
wchain
Ecoboost
USA
May have a water pump with impellers destroyed by nasty coolant.
