Need link for rod bearing kit
dohcsable
Gold Calipers>*
Indiana
I cannot find the link I had for thecomplete rod bearing kit. Which was bearings, gaskets, and seals.....
anyone know off the top of your head?
Andrew
dohcsable
Gold Calipers>*
Indiana
thatnk you both, I just couldn't remember his web address.
Andrew
dohcsable
Gold Calipers>*
Indiana
I also could use a place to get half inch longer pressure plate to flywheel bolts for an upgraded clutch
Andrew
Storm-Chaser
Shit Louis
Actually, it's like 1-3/16" in length and has an integral washer.
Obsolete from Ford, but their clutch kits still include the pressure plate bolts.
SHO Nut sells a pressure plate bolt/washer set - actually they're capscrews with lockwashers. His kit is ~$5 but you also have to figure-in shipping.
The bolt is an M8 x 1.25mm x 30mm - get grade 8 (OEM is either metric 9.8 or 10.9).
So, finally starting to getting around to getting it all done?
dohcsable
Gold Calipers>*
Indiana
yea, getting ready to get her started....I need it done and broken in by may
I have a set of bolts that were included with the spec flywheel I got from james, but they are only the length of the thickness of the pressure plate...
If shonut has them, can anyone find me a link....I'm to dumb to navigate thier site in what I'm looking for.
Andrew
Storm-Chaser
Shit Louis
Oh come-on . . . it's not that difficult!
On the main page, click on the link titled "Clutch" . . . ,
. . . third item below the subsection "Individual Clutch Wear Parts".
dohcsable
Gold Calipers>*
Indiana
ok, checking now.....once thats done, its time to decide if I'm going out the top or out the bottom....I'm kinda scared to get into subframe issues
Andrew
Storm-Chaser
Shit Louis
It's not a big deal pulling the subframe.
If you're worried about finding something bad, I think you would want to know it's there and get the problem fixed, versus driving around with a false sense of security.
In my opinion you're more likely to damage something pulling the engine and transmission (eg. snag a harness, hose, power steering reservoir, etc.), than dropping the subframe and transmission. In the former you're going to have to disconnect a lot of engine related components; the latter the suspension related components. The main advantage of pulling, is that a 60K is much easier to do out-of-car, if you plan on doing it.
I was running parts/tools errands for Matt (LOUDSHO92) when they were physically pulling his engine at the convention, but he and a few others here can outline the potential problems with out-the-top procedure.
dohcsable
Gold Calipers>*
Indiana
oic....hmmm, I just don't want to have to replace subframe bushings yet
Andrew
Storm-Chaser
Shit Louis
Go to the salvage yard. You can probably walk out with four very good condition Gen III rear bushing sets for $20 . . . .
