My baby is running great again..... Well sorta
Tha Green SHOrnet
Denver, Colorado
My GEN III was stalling real bad. I drove it to the dealership and on the way there, it died on me 5 times. The said that the coil packs were bad, so the fixed them and now my SHO runs great, I THINK shrug WHAT IS THE AVERAGE TIME FOR A GEN III FROM 0--60. I timed mine today and it went from 0 to 60 in 10.7 seconds. That does not seem right at all. What can I do to get a better time? Injector cleaner, fuel cleaner or what? :confused:
89 Gary
Millbury, Ma.
If the "dealer" found out it was a coil pack then I'm assuming he did the "computer check" thing and hence everything including all sensors are ok? I can run to 60mph in 10.6 seconds. Either your fake Rolex is out of wack or your dealer didn't check squat! A professional fuel system cleaning is highly recommended evry 30-40k miles. Get it done if you believe it's the cause. You should be about 7 seconds.
twr
whoohoo
half-way there, I think.
One Thing to remember, here in Denver (5280 feet above sea level) 0-60 times increase by almost a full second. Question - were you timing it yourself, or did you have someone else in the car timing it for you?? If you did, the extra weight will slow you down too.
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
I dont think that is that far off from normal. My 93 ATX did it in about 9.5 secs, I wouldn't be surprised if yours was up there. You might want to replace all the coil packs though, if one goes, they all will.
shobroooo
