MSD injectors?
40BelowSummer
Puerto Rico
I am looking for some bigger injectors for my S/C SHO as the current 36lb's are not big enough for 400+WHP.
Ive started to do a little research and noticed a few threads where Doug@FPS mentions that he uses 50lb MSD injectors in some of the S/C SHOs he builds.
Anyone have any thoughts on using these injectors? I searched and it seems they arent ever really mentioned.
http://www.msdignition.com/fuel_5.htm PN 2013
TIA :thumb:
SHO Dude
Sponsoring Vendor
Sponsoring Vendor
Southeast
I'm running the 50lb-ers in Jason's car and it's got just enough to make 330hp to the tires (thru the ATX).
40BelowSummer
Puerto Rico
So when looking for injectors I want some high-Impedance, Bosch style injectors with removable tips, correct? As long as it fits this description will they work?
Anything else to look for when searching for an injector?
texantony
Arlington, texas
Yea, make sure they send you a flow chart with the injectors showing that they all match each other or pretty close. You will need modified rails.
at least all of mine come with flow charts:shrug:
yamahaSHO
E85 whore
Arkansas
Injectors and you just don't get along.... 50lb/hr injectors are good to over 650hp.
40BelowSummer
Puerto Rico
Jason, I was thinking 50lb injectors could be too small for me, or at least in the future.
520bhp x .55 BSFC / 6 injectors x .80 duty cycle
286 / 4.8 = 60lb fuel injectors
If 50lb injectors are indeed good for over 650hp then my search for larger injectors is over.
adidas_kn
LOWSHO
Houston Texas
This sux. I have the last set of SHONUT's modified Accel 48#ers sitting on my shelf unused and now I am told I need 60#'s or larger to support my upcoming supercharger setup. I was always told that each cc of an injector can support 1hp so the 48# injector is right around 500cc so I would think they can hold around 500hp. But I guess these are thirsty engines.
40BelowSummer
Puerto Rico
Search google for "fuel injector calculator" You can determine which size of injectors you'll need.
yamahaSHO
E85 whore
Arkansas
50lb/hr / .55 x 6 = 545hp x .8 = 436hp @ 80% DC.
You'll most likely be fine. I've seen bigger power of smaller injectors and they weren't close to maxing out.... Even at lower altitude
Another option is to boost the fuel pressure with a adjustable fuel pressure regulator.
SHOMurph
Ford B@stard
Arlington, TX
Hey is this car still going to be at the convention!?
Can't wait to see the Texas Mystery Car!!!
Nice to see you around J. We all are always curious about what's going on with your project car.:thumb:
kaoticSHO
Thread Killer
sitting upon the Grimpon
Well Luigi, to be honest after losing my dear mother and accepting the challenge of being a full-time 24/7 caregiver for my 90 year old stage IV alzheimer's stricken father everything else just doesn't seem to matter anymore.
I once thought that with money you could buy anything, what a life lesson I was shown.
Perhaps one day I will return to the living..
I lost my dad not long ago. You're right, money isn't as important as we sometimes believe. Sorry to hear about your familiy. I hope you get a break every now and then so you can catch your breath.
Best wishes from me as well.:salute:
sho_sc
Georgetown, KY
You can support a whole lot of wHP with 48# if you increase your fuel pressure. 59 lbs of base fuel pressure with 48# injectors will support well over 600 cHP. Now the problem really is the fuel lines (including the intank lines) and the 255 lph intank pump ... from my calculations (and experience) you start seeing the effects of fuel starvation with about 430 wHP with the OEM lines and 255 lph pump.
