Lower Timing Belt Cover
Best Sho
Hudson Falls, NY
Does anybody know where I can get this and can just the gasket be replaced? Lower Timing belt cover.
Also I lost 2 screw's that go to the timing belt covers. But as of yet I'm not sure which 2. Does any have the 2 or know where I could get them?
Thanks, Mike
Here's link in case no sho....
http://mediaservice.photoisland.com/auction/Jun/20036168517243362693024.jpg
http://mediaservice.photoisland.com/auction/Jun/20036164354626369194829.jpg
The bolts are different between the 3.0L and 3.2L and you did not state which you have. Not knowing which bolts makes it even harder for us to help you. Try some of the remaining bolts in the open holes to see what fits.
They are all size M6 bolts of differing lengths. The lower timing belt cover bolts are different. The 3.0L has two shorter bolts on the order of 25 to 30mm and two longer bolts of 80mm length. The 3.2L has three of the shorter bolts and one of the longer.
The two 80mm bolts are also useable for removing the crankshaft timing belt pulley. I obtained a pair strickly for pulley removal duties. This makes it much easier when working on the 3.2L's front end.
poffffd
