Joining the FI club ** now w/ pics**
Bizzy
COliveira95:
AutoSHO:
I think Chris wants it "Broken in"...
... not broken.
:D
Agreed, good thing it has a quaife and you can't blow another diff pin... :D
I think the gears are next in line. :)
Beautiful car Chris, you will take me for a ride right?
(and for you pervs out there....not that kind of a ride either.)
Chris Benvie
Every so often
RedSox Nation
smithsil:
are you re-building the bad motor or starting with a fresh 3.0L?
we will see once its all apart. Might just start over depends on whats ruined.
Beth, you know i'll umm take you for a ride.....
revhardSHO
Seattle, WA
Chris Benvie:
smithsil:
you were able to start the engine with a thrown rod?
drivinhard
Gainesville, GA
std rod bearing width is .057" thick, which when removed from the crank/rod/piston stroke equation, puts the piston beating on the bottom of the cylinder head. You'll ruin the piston/head very quickly doing this.
I saw a motor like that, guy kept driving it, the piston eventually broke into pieces, the pin stayed in the SE of the rod, and tore 2 gashes down the cylinder wall in the block in the next couple of strokes.... At this point everything went to **** in a handbasket, some of the piston pieces were ejected through the oil pan, the rod went "U", the crank locked, and the main cap girdle broke in 3 places. It looked like a grenade went off in the oil pan. Via the crankcase vent to the TB/intake, I actually found piston pieces and piston ring fragments in the surge tanks.
Chris Benvie
Every so often
RedSox Nation
Driven twice, 1min onto the truck, 1min off.
I am aware of the piston slapping the head. I actually figured this was the problem in the 1st place. Either way i am prepared for it. I knew that was worst case scenario.
thanks mark
revhardSHO
Seattle, WA
drivinhard:
my seadoo did that. Arent two strokes reliable? madflame :rolleyes:
<small>[ March 24, 2004, 01:20 AM: Message edited by: smithsil ]</small>
revhardSHO
Seattle, WA
What is that bracket bolted to? The front head?
stops belt slippage?
Chris Benvie
Every so often
RedSox Nation
Yes, does stop belt slippage, i believe that a few people will be "taking measurement" cause i have heard the many "mewants"
DemonNeno
SHOCAGO Freak
Skokie, IL
Chris, very clean and stealth man! I likie!! How much do those rims cost? It's hard to find a better looking rim then a slicer n the Gen1.. Your rims are dead sexy, though! beer
