Is it time to shot my sho?
Fudog
Sac town CA
well upon more reading and a closer inspection of the inside of the car.
I found that all the buttons work fine(both seats too), Its got a cd/cass player havent tried them yet. Afraid to lose a cd or cass. But the radio works and the sub is blown. Is it normal for there to be a release for the gas tank door in the trunk?
All-n-all pretty good shape :****: except the drivers set which is worn :frown: but the rest are fine. Its full mocha leather by the way. :D
I tried to get a better look around the engine with a flashlight and if the hood hadn't dropped on my head :bonk: id still be lookin.
Add that to the list of parts :rolleyes:
From what i could see there is oil in the plug wells, and oil along the back of the motor seems mostly towards the timing belt area. But i did see a little oil puddle :frown: back there on top of something. It was the back left side(leaning over the engine)
SHOguy 92
Duluth, MN
Tighten up the bolts on your pan thats on the bottom of your tranny if it's leaking tghats simple. If that don't fix it, get a seal from someplace (probably won't be much) drop the pan and put on the new seal, real simple job is my guess.
Fudog
Sac town CA
Well the shop said the bottom and side pans were leaking bad. Before i took it in I put 2 quarts of tranny fluid in the car. And most of the oil ran out on to the ground. I thought read around here some-where that u nd to drop the subframe to get to the tranny pans. I dont have jack stands yet to try that. I figure if i can get a pair of stands then ill try and ive got to fix the front(?) motor mount too.
