I can turn my crank?
WILL SHO U
Sooner or later
Home of the Indy 500
Just changed the harmonic balancer today and apon removal and the install, the pulley turned. If the pulley turns, doesn't that mean the crank is turning? As the bolt got tight the pulley turned more. Im not sure if the torque wrench is accurate (110). Should it be that easy to turn the crank? The battery was disconnected and key was off.
Ishodu
The motor will turn yes. You can hold the pulley with a strap wrench or clamp a C clamp on the thing so that it cannot turn either.
USHOMEISHOU
Troublemaker
New Mexico
BUT WATCH OUT HOW MUCH YOU TURN YOUR CRANK! IF YOU TURN YOUR CRANK TOO MUCH YOU'LL GO BLIND!:thumb: :rofl:
n8rsk8r
Hey Where's my post?
Olathe, Kansas
:lol: thought that was pulling on it? Oh yeah, pullin on it will make your palms hairy!! Either way.. WATCH OUT!!:eek:
LJRuddy
Pop lock n drop
Poaceae fields
socialdeviat
Ca
You guys are terrible.
Yes use either a thick 6in strap wrench or if you have a MTX you can try putting it in gear, and parking brake and such.
HotRodKid
mmmmm ... turbo
Western NY
the other day i spun my engine over some just using my hands on the crnk pulley ... and thats w/ everything but the PS pump on ...
110ft pounds will definantly spin a crank (or move a car)
ribeye2065
