holy cow its alive
matty
Southern Cali
whats up all,i did the timing belt crank seal cam seals today for the first time ever.ya so what it took me all day but it works thanks to phoenix progect site:hail:but im getting a slight whine noise does anyone have any ideas:thumb:
Zap
West Bend, Wisconsin
Is your SHO MTX or ATX? If MTX and the timing belt tensioner is too tight, it can cause a whining noise. It could also be an accessory belt that is over tightened.
Does it change with RPM?
Zap
There is an adjustment hole in the timing cover to check the tensioner. Since it is manually adjusted it is possible there is too much tension. During a 60k I had mine a bit tight and after re-adjusting it the car was fine.
Also, did you replace (and gap) the CPS properly? That can make a weird noise if you didn't....
A mechanic's stethoscope would also help isolate the area where the noise is coming from for sure.
