Help-temperature
bigsho
sterling va usa
Today I replaced the t-stat and sending unit. I started the car temp went up to m then went down. After running for a while it went to n and stayed there before I turned the car off. Any help or ideas I don't know what else to do. Thanks
Robbie
95 MTX red
SS SNORKEL
26 sway bar
24 sway bar in box
SHO NUT motor mounts in box
IPT 3 gauge pod in box
jthomas68
Area 51
Most likely there is air in the system.It`s common when working on the cooling system,and should work it`s way out within the 1st 10 minutes.
Jeremy Thomas
Juiced 91+
SHO Pic Of The Week:Owned by Jim Filzof
