Heat
JMoff92
Rochester, NH
I posted a few weeks ago about my blend door actuator possibly being the source of my no heat problem.
But before I pulled back the dash to check out the BDA, I was wondering if a vacuum line would have anything to do with the problem. Because I changed my heater core last spring and was thinking that maybe I missed putting a vacuum line back on.
So do the vacuum lines have anything to do with the car producing heat?
projectSHO89
SHOless In St L
JMoff92:
No, but Fuse F17 does.
The vacuum supply is used to switch the inlet and outlets for the airflow. The actual blend door is electric (on an auto climate system).
Steve
