Head cutaway pics - where are they?
MerkXRTurbo
Vancouver, WA
Hey guys, sorry if this is posted in the wrong section, but a few years ago I came across a website that showed a pair of SHO heads cut down the center of the port, along with flow numbers at various lifts, but I can no longer find it. Anyone know what I'm talking about? Is it stilll on the net?
1993MTXSHO
Its a Taurus...
Jersey
I have them but they are on my computer at home, if no one posts, shoot me a pm this weekend to remind me and I can post them up for ya;)
92sho16
b00sted
Liverpool, NY
[/IMG]
MerkXRTurbo
Vancouver, WA
Yes sir it is indeed. It just shows that there's not a lot of factory imperfections to be improved upon within the ports (without removing a lot of material and losing velocity in the process), which I've found out already as I'm in the process of reworking my heads right now. Pretty much I'm just smoothing out the rough surface of the ports left over from casting (is that a sand cast???), and then I'll be polishing it to a nice surface. By the looks of it, the place that needs to be taken care of the most is the valve shrouding in the combustion chambers. Besides unshrouding, the chambers are getting a nice polish themselves, to help fight detonation causing hot spots under big boost. :woo-hoo:
Phoenix
SHOHOLIC
QC , Canada
Yup , nothing much to do cept some gasket match and some polishing.
I didnt go with the valve area (kinda tricky) but I did this , opened up the chamber a tad on the edges. I donno what gains on this , cause when I did the re-build I slammed everything in one shot so I cant tell what mod does what HP.
NovaSS
Project MINIGUN
That's similar to where I'm starting with the chambers, but I'm doing a full polish on them. :)
After the block is at its final bore diameter install the head on the bare block and scribe the outline on the the bottom of the head. How open up the area around the valves "wall side" to this line, you will end up with a clover leaf pattern.
Do a google search for valve unshrouding.
MerkXRTurbo
Vancouver, WA
I was thinking more along the lines of opening it up all around to the size of the bore, not just around the valves for the 4 leaf clover pattern. Any kind of lip what-so-ever seems like it would be a point of flow disruption. Here's a quick MS-Paint to draw out my theory:
Engine drawing
NovaSS
Project MINIGUN
DO NOT open it around the entire bore!
Do a google search for "quench area" and you will see why this area is needed is a gasoline fueled engine.
NovaSS
Project MINIGUN
I've studied quite a bit of head porting and had not come across that phenomenon. Thanks for the info. :)
Its pretty neat and it works, I built the big block in my Nova with a very tight quench. It runs 11.0 -1 on the street on 93 octain and NO detonation or preignition.
victorymike18
Green Brook, NJ
So, it appears that the V6 heads are very well designed. The intake port is at an excellent angle, but it looks like both the intake and exhuast ports could benefit from some slight work to smooth the castings.
The V8 head adds a few engineering tweaks, yet I find it odd that there was not a substantial Hp increase by comparison...
Once I get the heads off my motor, I will be doing a mild port and polish to the entire port, and some very conservative work to the combustion chamber. A common mistake that people make is to try and re-engineer the ports when they go in there.
dan.delargy
