Yes sir it is indeed. It just shows that there's not a lot of factory imperfections to be improved upon within the ports (without removing a lot of material and losing velocity in the process), which I've found out already as I'm in the process of reworking my heads right now. Pretty much I'm just smoothing out the rough surface of the ports left over from casting (is that a sand cast???), and then I'll be polishing it to a nice surface. By the looks of it, the place that needs to be taken care of the most is the valve shrouding in the combustion chambers. Besides unshrouding, the chambers are getting a nice polish themselves, to help fight detonation causing hot spots under big boost. :woo-hoo:
