getting warm
JIMSHO
VERMONT
my 94 atx is runing warm put new thermostat in still the same any ideas
JIMSHO
VERMONT
runs up on the higher side of the gauge. it just started a few days ago. droped a gauge in the radiator it reads 230 deg. thinking nabey the water pump?
projectSHO89
SHOless In St L
JIMSHO:
Possible, but not very likely. These pumps have a metal impeller that rarely (I've not heard of one) fails.
Far more likely is a clogged radiator, restricted hose, or a malfunction in the fans.
All of this assumes, of course, that you actually have a fault in your cooling system.
Steve
JIMSHO
VERMONT
i pulled the hoses off put a garden hose in the rad. flows nicely both fans run going to pull water pump . to see what it looks like . got to do a timing belt anyway i will let u know how i made out.
JIMSHO
VERMONT
got it solved it was the water pump. it had a little play in the brg. also changed the timing belt. since i was 3/4 of the way there. runs great know. and no i didn't put the thermostat in backwards :)
