thecrew2999
3.2 MTX SHO
ok where is the fuel pump relay located? i keep throwing a code saying about the fuel pump relay which is 543 code.
thanks for any help
thanks for any help
SHOZ123 said:It's in the CCRM. If it is the low speed fuel pump relay don't worry about it as you don't have one.
TYSHO said:Bypass the inertia switch in the trunk, or at least test the connector and see if power is running to it when someone turns the key to the on position. You need someone back there looking, because after 2 seonds and without the engine turning, the relay will kick back off.
Do you hear anything clicking in the engine bay when you put the key in the on position? If not, it's an idication that the IRCM is not receiving power. Run the ECC port test and see if it kicks the relay on.
1993MTXSHO said:matt if we ever get together to do my trans or w/e I have one of those relay boxes from my 94 atx with the J on it. You can see if that fixes you problem![]()
thecrew2999 said:i dont know if i mentioned but the car does run but it keeps idling up and down real hard then stalls itself... i keep getting the code 543 for the fuel relay as im starting to figure out
thecrew2999 said:no cuz i keep resetting the code and its still there even if the car dont stall
and no thats not the code for stalling the car its
556 (O,M) Fuel pump relay primary circuit fault - Power / Fuel Pump Circuits
thecrew2999 said:its worth a shot because i mean it dont idle for a damn and when i hit the gas im starting to think the car laughs at me and then dies
SHOZ123 said:With the key on and a ground wire, ground wire the connector in the fuel pump slot. This will force the fuel pump on continuously for testing.
