hopefully you guys can help me out. I purchase a mocha 1991 with 110k for $500. Owner kept it sitting for 6 years. He said it had a bad clutch and was going to use it as a parts car, yet he never took any parts off. So i bought the car, gave it the normal tuneup, plugs, wires, valve cover gaskets, fluid change, tires... My problem lies with the fuel delivery. the inertia switch was disconnected and the fuel pump was being powered by the trunk light. So i started to try and figure out the reasoning, and the ircm has a date on it from 2001, so i know this part is not stock. I searched on the forum about the ircm and based on what i am reading (correct me if im wrong) J code which is what i have is for an automatic car. So i assumed they replaced the wrong part and thats why the car sat for so long. So i went and got a M code ircm, hooked everything up and my only problem is when i turn the key on, the fuel pump doesnt prime for the 1-2 seconds that it should, and the car wont start, however if i put power to the inertia switch for a few seconds and prime it myself, the car will start and once its running the car will power the fuel pump itself. So i know the fuel pump works and the car runs, i just cant figure out why it wont prime for the 1-2 seconds it needs to start on its own. Please help.
