fel-pro spring bolt replacement?
frosho
WOLFMAN
Tyngsboro, MA
i found this on rockauto.
FEL-PRO Part # ES72142
DOHC Engine {Exh. ****** Bolt & Spring Kit}
part of a description mentioned the exhaust manifold so i wanted to see if this is the y-pipe to cat-back spring bolt replacement and if it only includes 1 bolt and spring or both pairs. thanks
AREA 91
PA SHO SHOP
Area 91
I believe it's 2 bolts, springs, and flag nuts for the cat back ******.
frosho
WOLFMAN
Tyngsboro, MA
thanks. can anyone else verify this? id like to know exactly what im getting before i order it
LeddZepp8687
The Keg Rider
Naperville, IL
yep, Its two spring bolts and 2 washers..For an MTX only though...ATX has no spring loaded bolt.
Hope that helps!
crystizel
