engine bay wiring question
Status
Not open for further replies.
showagon
howell mi
I have a 91 wagon with a sho motor swap, recently did 95 interior and front clip and door panels. Having problems with engine bay wiring cause of climate control, does anyone know how to get arid of it?
kputer
Howell, Michigan
Showagon, you put a 95 SHO motor in a wagon? I'd like to see that, I'm from Howell too. What exactly is the climate control issue?
showagon
howell mi
i had a 91 sho motor and its blown up so i got a 95 sho and put the doors, dash, frunt clip and motor but the wiring from the old engine is not the same so when i put the wiring from the dash though the firer wall the plugs dont mach so i was wonding if eny one and eny ide i dont what to chang the engine harness
HyperMikeD!
FordBastard07
Texas ***** Fugger !
Hello McFly...The sho wiring will not plug up to the GL dash components. The eatc is completely different, the clock is different , the instrument cluster is different, GL doesnt have fog light switch etc etc...
I would love to see this wagon you have. Post pics :rofl:
showagon
howell mi
******* fagit i have the sho dash to i allready had the car runing for a year then wanted to put the newer dash so it you cant help then shut the **** up
Cobraii976
I am an idiot
Is that the silver one I almost bought? Not sure I understand the question but I'm willing to actually help you out. Or you can take a typical SHOFORUM beating and keep asking questions.
oh_SHO
Ohio
This thread is on its way to being locked & deleted if you two keep that crap up.
You may want to use the engine wiring from the 95 you pulled the dash from. The wiring for a 3.0 vs 3.2 is different. If you don't want to swap that in good luck hacking it successfully.
showagon
howell mi
thank you for the helping info oh sho do i have to change the hole engine wiring or just the starter and wires because the starer syonide is located on the firer wall on the wagon and on the 95 it is on the starter
oh_SHO
Ohio
Not sure. Can you give us some more details? Did you leave the car as an ATX or make it an MTX? What year did the motor come from? I am a little confused since your using genII stuff in a genI... I am assuming that everything worked correctly before you changed the dash. Also if you didn't change in the heater box and stuff from the SHO you might have to ditch the climate control unit (if it is a hard button sell it on e-bay!) and use manual controls. There are motors and sensors in the heater/ac box that talk to the climate control units.
I think to make the wiring work properly you will have to use the genII engine harness because of the starter and different wiring plugs. You could try just changing the starter and associated wiring... Sorry this area isn't my strong point.
Shoaz
Studly dood
Scottsdale, AZ
Sounds like you have a GenI starter and a GenII harness. If so, all you need to make the GenII stuff work is a starter from a GenII. They're smaller than a GenI starter and a GenII starter from an ATX or MTX will work.
Don't change the engine harness to an ATX harness unless that's what you had in there. There are several things (including the dash wiring and computer connector) that are different between an MTX and ATX. Whatever engine harness you use you'll need a computer to match it, (i.e., ATX = ATX). I guess I'd suggest rewiring the dash harness to work with the MTX engine harness or get a dash from an MTX.
Markus
Ottawa, Ontario, Canada
You've confused me. It sounds like you had a 91 SHO motor in the 91 wagon and then it blew up. This would mean it was running in the wagon at some point. If this is so I don't see why adding the 95 SHO engine should be causing you this much trouble? Are the wiring harnesses for the 91 SHO and the 95 SHO that much different? Are the 91 SHO starter and the 95 SHO starter different?
Also, pics would be great!
Status
