ECT Coolant Sensor Replacement
BenBrausen
Minneapolis, MN USA
How do I get at the ECT sensor to replace it? I don't know how I'd even get a 1 inch wrench in there to remove it. doh Is there some kinda trick to it??
Rockledge
Pluggin' away
Connecticut
Replaced mine a few months ago. A crows foot socket at the end of a 6-8" extension worked well for me.
Put a dash of pipe sealing paste or a strip of teflon tape on the threads of the new sensor before you install it.
You should also drain a little coolant out of the system and disconnect the battery before replacing the sensor.
:cool:
<small>[ December 04, 2003, 06:29 AM: Message edited by: Rockledge ]</small>
yamahaSHO
E85 whore
Arkansas
If you cannot get your socket around the connector, use a flat blade screwdriver and break it off... Then you should be able to slide the socket right on it.
EDIT: I tried a deep well socket... It just was not deep enough frown
<small>[ December 04, 2003, 06:38 AM: Message edited by: yamahaSHO ]</small>
Ishodu
When I did mine I just used a deep socket on a 1/2" drive ratchet. Not alot of room but enough to do the job.
