differences in 89-90 rear seats
oldyak
memphis,tn
I have been looking for replacement rear seats for my grey interior 1989.
I found a seller,but his are from a 1990..
ant difference?
Mels
SHOVELHEAD
Brookfield CT
I myself replaced the original seats in my '89 with those from a '90 or '91 just a couple years ago. There were no differences in either fit or mounting to speak of.
If you need to replace that seat, and you've found a replacement at a reasonable price, I see no reason why you shouldn't go ahead and swap 'em out.
mrecoolgar
SHO NUP
Hershey-PA
I believe the side bolsters are different in size.
And I know the headrest are sewn different.
The 89's have the material running side to side.
While the 90-91's have the material running top to bottom.
Nothing that effects anything, just not 100% correct.
I believe their is no difference in the rear seats.
oldyak
memphis,tn
difference between 89-93 rear seats
seller has now indicated that his seats are from a 1993..
will these fit on my 1989???
jelloslug
Digital
Greenville, SC
The 93 seat is flat across the top rather than having the 2 "headrest" bumps. It will fit but it won't quiet look the same.
WI93SHO
Eau Claire, WI
I ran into some fitment issues when I replaced my 93 seats with some from a 92, the rear lap belt latches come through the bottom seat in 92 (and maybe some other years) and they come between the seats in my 93.
I just had to unbolt the latch from the bottom of the car and rotate it 90 degrees to make it work, so they are horizontal vs. vertical.
mrecoolgar
SHO NUP
Hershey-PA
Oopps, I forgot about that.
The early belts will work with the later seats.
But the later belts would not work with the early seats.
