Deep in the plug wells, he struck oil
dstig1
Hudson, WI
Here are shots of my plug wells. The one on the right is #6. You can barely see the plug tip. #5 you will note, is totally submerged.
The odd thing is I had no driveability issues, and all 6 plugs are like this.
Good thing I got new seals...
I'm doing a 60k - top and front stuff, plus rod bearings. Plus my rad fan motor is toast...need a new AC clutch...and I should tear into the rear suspension too...
HoustinoJillian
name's JUSTIN
usa
you have to upload your pictures online somewhere for them to show up. can't link from your computer. use www.photobucket.com
dstig1
Hudson, WI
Sorry - figured that out after I posted (first try posting pics on this forum). No time to set up a photobucket right now - I'll catch it later. The car is calling! And in many pieces!
turbolarry
lancaster , pa
looks like that one cam lobe is worn too ... is the cam blue right there from overheating ? maybe not getting enough oil to that one lifter ?
dstig1
Hudson, WI
Nah. Just bad lighting. Using a LED flashlight to try to show deep into the wells. Everything was pretty happy looking in the top end, other than the oil in the wells.
dstig1
Hudson, WI
Beats me. I did my last 60k about 4 yrs ago, which was the last time I pulled a plug wire. Everything was dry at the time and I used a little bit of RTV on the plug seals. Reused the old gaskets last time. This time new gaskets, no RTV. New wires too.
I'm still surprised I didn't have any misfire issues (that I could tell).
