Crank & oil pan
wjayg
Idasho
Boise
I NEEDED ROOM SO I SCRAPPED EVERYTHING BUT THE CRANK & OIL PAN
I will be taking parts to scrap yard soon as I need to make room in my garage for fiancée and her kids. Make offer and I get get rates through work and can ship anything in lower 48 States for $1 per pound
I would let the crank go for $50 plus $25 freight
Clean Oil Pan
Make some offers
8542904564 43c2c3dd9a
8541815651 8ec5350881
Goodyear Gatorback Idler Tensioner $10.00
49005
7428606990 57a03a03f0
vortex2450
Buying Parts...
North Carolina
Do you have a 3.0l timing belt tensioner stud? It's threaded on both ends, the 3.0 stud is longer than the 3.2 stud. Please and thank you.
wjayg
Idasho
Boise
Tensioner Stud
Both timing belt tensioner are bolts, one is in a triangular housing and the other is attached to an housing but both are bolts, one has a nut at the back that slip inside the housing and the other just screws down? Give me more info like MM and lenth and I will look, there is so much stuff I am sure it is there somewhere
wjayg
Idasho
Boise
302 Parts
Yes, yes, and yes but as stated I have kept most parts off the 3.2 and though I am not against selling them it would have to be an interesting offer and you would have to buy all 6 rod/piston assembles
vortex2450
Buying Parts...
North Carolina
No, not the accesory belt tensioners, the timing tensioner stud.
it goes here:
The stud which the tensioner rests on, the tensioner that tightens up the timing belt which connects the crank to the cam shafts is what I'm talking about.
thanks.
-Josh
MarcusKars22
Back in the Game
American Fork, UT
Where in Boise are you located I live off of Lake Hazel and Maple Grove may have to take a gander out to your place.
vortex2450
Buying Parts...
North Carolina
In the top of the first picture, I spy what appears to be a supercharger attached to some plumbing protruding from that green box, what's that go for? :D
-Josh
wjayg
Idasho
Boise
Water Pump
No I wish it was a supercharger! Water Pump
wjayg
Idasho
Boise
New Pictures-Parts Must Go
Must Sell
jimtash
nc
Looking for the lower timing cover inspection door and also a 3.0L timing belt tensioner spring.
wjayg
Idasho
Boise
More Parts
Gen I bra- $40
Gen II bra- $40
Gen II Sunroof deflector- $40
email for pics
wjayg
Idasho
Boise
Parts
Any small part $10 plus freight, larger parts $20 plus freight
