confused boggin feelin
89shofun
Guest
franklin wi
ok I removed silencer cone then removed intake painted it and reinstalled now I get a bogging feeling below 3 grand. I know it didn’t do it before it sound like im accelerating from an dead stop in seconded when im in first, is it my plug wires I did remove them 3 fell apart I attempted to repair I don’t know what else. Whats the sensor opposite the throttle body when I painted it the piece were it bolts on was painted over is that my problem plz help thank you.
kickeralpine
ohio
thats the dis opp side or trottle body and you dont want paint where it mounts down it needs good ground. and your wires may be no good or firing order is off .
Jaz2099
Rockford, IL
The DIS ignition module. It needs a good ground as said, so if there is paint it may not be grounded properly.
LookAtThatSHO
Who's SHO Daddy
Rochester, NY
89shofun said:
no the cylinder looking tube across from tb thx
I believe you're referring to the Idle /Air Control Module (pictured below). I don't believe this is contributing to your power loss. Did you replace the gaskets when you reinstalled your intake? This may be the culprit, but I would suggest getting new plug wires as well.
IAB
89shofun
Guest
franklin wi
IAC thank you finally someone got it ok ill get new wires if it still does that after new wires what else could it be im hopeing the wires are it because 3 fell apart when removing thanks everyone
oh my maf when i unplug it my idle goes way up instead of car dying or stalling is my maf shot ? thx again
LookAtThatSHO
Who's SHO Daddy
Rochester, NY
Wait, I just re-read your first post. You said that you painted over the area where the IAC bolts on? Did you just leave the module off then? If so, that would definitely be your problem :bonk: FYI, the SHO will run with the MAF unplugged, but it's probably not a good idea to leave it like that...
89shofun
Guest
franklin wi
ok i reinstall silencer cone car is better no iac is installed but yes its painted were it bolts on thx
yes new gaskets on entire intake and i had to remake clamps for the snakes i loosened one today and i heard air leak so i know they were tight here motor pic
Sh 0007
Sh 0005
Baddflash
Edmonton, Alberta
This is the DIS module FYI. Yes wires are a good place to start.
kickeralpine
ohio
silencer cone wont make it bog mines been out forever no problems. your wires have to be bad you said you had to doctor them up.
MusPuppis
Kentucky
Pulling the codes may not be a bad idea.
Another idea is to get some starter fluid from Advanced or Autozone or whatever (less than 2$ a can) and spray around the ISC, snake boots and runner gaskets. If you have a vac leak hidden somewhere it tends to suck in the starter fluid and cause the idle to rise a little bit. Decent method for searching out vac leaks.
Have you confirmed the secondaries are closing? At engine-off they will be open, but close upon seeing vac below 4-ish (is it 4300 or 4 even?). Always possible when hooking the intake back up a line got pinched or didnt get connected. Granted, I disconnected mine on purpose just to get and idea as to the "feel" and it didnt bog.. but it did feel sluggish.
Jes my amatuer opinions.
Really though, if your plug wires came apart, they could be the culprit, heh.
no iac is installed
Erm.. I'd install one and see what happens.
89shofun
Guest
franklin wi
fergot to tell u i removed my intake horns also i regret it and am planning time to reinstall regardless of if its the real problem yes my secondaries are good i ran codes check the hlp thread thx
oh iac is installed always has been
NeedAPartsCar
Yamaha Intack!1
Kentwood, Michigan
Forgot to tell you that I removed my intake horns, and that I regret it. I'm planning to make time to re-install regardof it's the real problem. My secondaries are good, I ran the codes. Check the help thread. Thanks. Yo.
S
shoebilly
Guest
When you remove the cone from the air box you will get a bogging sound, not a feeling.The feelings are phsycologoical. The problems that already exsisted you now get to hear.
