car wont start after removing battery and belt
xxtattootearzxx
pennsylvania
:hail: thnx for eveyones help with the whining noise ....... it was the water pump .
now ive got a new problem .
i just found out it was the water pump . i took out the battery and got the belt off played with pulley on water pump and it squeeked as i turned it so know i know that was it . NOW i have to drive to the parts store and order the part but now THE CAR WONT START! after i put the belt back on and the battery in i tried to start it .... cranks but wont turn . i tried to hit the reset button for fuel pump and it didnt help . i hvae no idea why it wont start . plz help :hail:
xxtattxx
xxtattootearzxx
pennsylvania
wow i feel stupid
got it started ....... i must have caught my sleeve on somin cause the harness was unplugged on that box that says motorcraft on it that is on the side of the engine ...... whatever it is ...... but problem sovled .
....... found oil all over spark plugs ?!?!?!?!?! anyone know what thats all about?
EMB2580
Mike is a L O S E R
Zion, Il
Good, for you, mine has beenn maikng a whilning sound ever since i had it, I have been told thta it is the water pump, but not 100% sure. it seems to go away with clutch depressed. Because of the drop in RPM's perhaps? also did you notice a burning rubber smell, Mine does when it gets hot. how hard was it to put on, how much did you have to take off? help is greatly appreicated. P.S. That conector that says MOTORCRAFT, That is the DIS module, why it's on that side and not closer to the coil pack is beyound me :nut: . but that would DEFINATLY cause it not to start. LOL
EMB2580
Mike is a L O S E R
Zion, Il
Oh, sorry didn't see that other thing you said till now. Oil in the plug wells, means you have bad valve cover gaskets. VERY common on SHO's, but I've heard it is farly easy to change them.
EMB2580
Mike is a L O S E R
Zion, Il
Oh, sorry didn't see that other thing you said till now. Oil in the plug wells, means you have bad valve cover gaskets. VERY common on SHO's, but I've heard it is farly easy to change them. and whle your doing that why not change your timing belt, hmmm?
xxtattootearzxx
pennsylvania
only thing that ****** me off ids last week spent 180$ on a power steering pump and it didnt take the whine out .... thats what everyone said it was so i just replaced it ....i should have checked the rest of the pulleys first but everyone seemed so sure that i didnt think twice.......200$ 8 1/2 hours and a wasted sunday but in the end its one less thing i have to replace later so fuggit . but all i did to find the problem in the end was take out battery for space to work , remove the belt .....had belt tool was easy . then play with the pulleys ...... water pump whined with just my figers turning it was obvios . still wish i'd have taken the time to look before i leaped ( so to speak) on the power steering pump . i just took everyones word instead of puttin in the wrech time to find out . lesson learned.
