one more question...(am picking up another SHO and my current one can be a little project..) are the ATX motor mounts the same between the v6 and v8, as in location on the frame?
When you say 'ATX mounts the same between the V6 and the V8' - do you mean between the Gen 3 SHO and SLO, or between the Gen 2 SHO ATX and the Gen 3 V8?
I think both answers are 'no' but my knowledge isn't exhaustive.
Does that indicate you're trying to put a Gen 2 ATX powertrain on a Gen 3 subframe?
The Gen 3 SHO transmission mount is considerably different (and significantly more elaborate) than either the Gen 1/2 MTX or ATX setups, or the Gen 3 SLO setup.
The amount of surgery that other swappers have had to do on the rear motor mount tower when using a Gen 3 SHO subframe indicates to me that the rear mount on the Gen 3 SHO subframe is substantially different from the earlier cars as well as the Gen 3 SLO.
Mine ('91 MTX) uses a late '98 Sable subframe, the stock rear engine mount tower is close enough (right height, hole needs to be slotted slightly) but the other two were a fabrication exercise. The car's not running yet (next week, really, just plumbing up the coolers and hooking up the exhaust and a couple last electrical connectors in the left front corner) but the engine is right where it's supposed to be in the engine compartment and everything fits nicely.
With the Gen 3 subframe and the ATX coolant bottle up in the fender and the two-row radiator the AC plumbing comes out a bit ridiculous too, it's got all that open space right in front of the compressor for plumbing but (to clear the MTX coolant bottle that isn't there anymore) it hooks over behind the fan shroud (where there's barely room because of the two-row radiator) then down and under (where it's likewise tight 'cause the Gen 3 crossmember's fatter and a bit further forward) to the accumulator. I'm debating whether I want to do something about that as well, cut up a set of compressor manifolds and shorten the pipes to move all the couplers/hoses over directly in front of the compressor and have my friendly local TIG artist put 'em back together, but then I'd have to find an AC shop to crimp new hoses on the hard lines...
