Burning oil
Hubes
Burl., MA/Chesapeake, VA
ok i have to put in about 1 qt of oil every 1k miles. i don't have any blue smoke coming out of my exhaust at all that i can see. and i don't smell any oil burnign which doesn't mean it isn't burning. will a 60k correct these problems or is it another underlying cause? help me correct this damn problem.
Hubes
i try not to drive it that hard at all. but i guess i get carried away. maybe i will do an experiment where for one week i won't even get to my secondaries and the next week i will drive normal. i don't open my secondaires all the time and have onyl taken it to redline liek a few times
Catfishphillip
Hammond, LA
You didn't mention checking under the car for leaks from the oil pan seal, oil sensor, oil filter, drain plug, et cetera - is it dry under there?
Shoman94
Maine
Catfishphillip:
I use about the same....front main crank seal. It doesn't leave spots anywhere but I can see oil under it on the pan.
Hubes
i havenlt seen a drop (knock on wood). i will double check and park it on dry level ground over the weekend to see if i can see any spots of leakage.
Catfishphillip
Hammond, LA
Park the car somewhere dry with a large piece of clean cardboard underneath. The next day, check for leaks on the cardboard.
Hubes
good idea....i will get some cardboard on sat and do it overnight if it doesn't rain. i think i have a small coolant leak but that is it but let me double check.
BeatDaSHO
Hatboro, Pennsylvania
yo man. i had the same problem as you. i had to put in a quart every 1000 miles but this was due to the front main seal. it leaked onto the cat below it and it would cause smoke. i put in a new seal and i've driven on it for 300 miles and no leak so far.....hopefully. And i hope i shouldn't have to put in a quart every 1000 miles. later.
Greg
