Lance Cheney
Well, that's one way to look at it, though I suspect the Cobra kit would still be a better option (lighter calipers, slightly larger rotor, and relatively cheap).
I was mostly looking at whether something like the Wilwood FSL setup that I put together would work (13.375 x 1.32" w/4piston calipers). i'm not sure it would be enough brake for that large car. It's almost double the $$$ to go to anything bigger Wilwood-based as you end up with more expensive calipers ($400+ each) to run 14" rotors vs. $160 ea or so for the FSLs, and you eat another $30 each for rotor rings in that size range.
-Lance
-Lance
