04/13/20........
Been a lil quiet, yea? Well besides the COVID-19 pandemic slowing things down, my engine builder also re-injured / re-aggravated his back (sciatic nerve specifically) which was causing numbness in his one leg, and in turn, severely hampering his ability to just simply walk around, yet alone consider performing any work of any kind. On my project, as well as any/all others.
So, in the interim, and thanks to my long time mechanic friend who's also been instrumental in this process, was able to source an existing/used flywheel. Which I've since sent off to an aftermarket vendor for inspection and/or potential upgrading.
Important to note, all 2010's, and 1st half of the 2011 model year's, employ a 4 bolt pattern flywheel. As you see in this pic, it is a 3 bolt pattern. Why the change? Well, the upgraded TQ sourced from GH is a 3 bolt (also shown in pic). Soooooooo the change was necessary for that reason alone, but moving forward, I wanted to be able to convince the vendor I sent the flywheel to, that there would be a larger market for the 3 bolt pattern, as more of them are "out there" versus the 4 bolt. Anyhow, still waiting to hear on that front.
Hopefully should be hearing from the trans vendor soon as well.
I may consider reaching out to DSS for axles and/or drive shaft options. Even if custom. This may be contingent on funds however, as once again, due to the COVID-19 nonsense, all overtime has been eliminated. All secondary employment also eliminated. Alternative, emergency scheduling now in effect, and minimum staffing has been LOWERED to historic levels. So, although I count my blessings for still having a paycheck coming, the pandemic is drastically effecting extra income. Ugh.
Finally, I received the following message from the builder over this past weekend (quoted and highlighted in bold)....
"Block is all final cleaned, prep'd, and final measured. Setting bearing clearances is what we were working on during the week. Piston rings have been filed and fitted. Just need to do the assembly and start gathering more measurements to set final compression and acouple other specifications." ----Max Power
So it seems his back is better now, and he's back at the shop get'n 'er done!
Builder also said he hoped to get some pics sent my way this week as well. So, just a little update. Hope everyone's well, staying safe and healthy, in these trying times.
