Blowin Trannys
91SHO2GO
manitowoc wi usa
I have a 91 Sho with a 5 speed and ive only owned it a month and went through two trannys.This sucks. What Lubricant goes in these trannys? Ive been using Dexron III. Thats what one of my books told me but im starting to wonder. Any help would be greatly appreciated!Im a first time SHO owner and i love the car but am lost on some of the details. Thanx!
SilverSHO
cartersville
First of all, how are you driving the car? If you're constantly doing burnouts and romping the gas, you will go through transmissions. These trannies are not exactly known for their durability, and lots of one-wheel burnouts will **** your differential. If you're taking it easy, the tranny shouldn't be giving out like that. Other than that, I have no idea why your tranny would be crapping out like that.
As for fluid, good old ATF works fine, or you could go with Redline or Amsoil tranny fluid, both of which I believe are synthetics (and from what I hear, well worth the cost).
Nick
Lt. Titanium 90 136k
Coneless, ACCEL 8.8 stainless steel wires,
SHO Shop solid roll dampers, Cherry Bomb Turbo II mufflers, snazzy blue valve stem caps
AIM: loudog6491
It's been so long since I replaced tranny fluid so I forget if Dex.III is ordinary manual trans fluid or auto fluid. Anyway the MTX uses ATF not the gear oil.
bensho92
man i had same problem with my 92 mtx, i always drive the shit out of it, and i went through 7 tranny rebuilds and then realised that i ned to invest 1500$ in quife LSD if i wanted to hot rod my sho, so far it has been 4 months and no problems.
SHODUDE
Valdosta, GA
Originally posted by luigisho:
Wasn't there a company mating up porsche trannys to SHO motors? hmmm....
Yes there is. They make the adaptors for them. The company same starts with a K. Does that help?
mailto:[email protected][email protected]</A>
1990 SHO FOR Parts
1991 SHO SOLD [email protected]
Need SHO parts?
Click here&gt; http://cgi6.ebay.com/ebaymotors/aw-cgi/eBayISAPI.dll?ViewListedItems&[email protected]
SHODUDE
Valdosta, GA
I only use redline in the trannys I care about. D4 in the 91-95 trannys and MTL in the 89-90 that haven't been rebuilt. DON'T do burnouts dude!
BTW, I have enough trannys to last even you a lifetime. Email me if you need one. [email protected]
1990 SHO FOR Parts
Need SHO parts?
SilverSHO
cartersville
Marcus, how much is the MTL? I've a feeling my tranny is telling me to change its fluid, and I've heard nothing but good things about Redline's stuff.
Nick
AIM: loudog6491
I have used the 1991 Ford SHO Owner's Manual specified Type F (or Mercon) ATF or the Redline D4. The Redline was used for about 50,000 miles but was lost during a clutch replacement. I have been just as pleased with the much cheaper Type F and a little of Ford's stinky friction modifier.
I am still using my fully functional, never rebuilt, original equipment, manual transaxle. To go through multiple replacements makes we wonder how much abuse those boxes are being subjected to. The SHO was not designed to be a drag racer. Now you know.
Scott
1991, 255K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/poly, Alum front SFB, SS front/rear strut braces,
6 disc CD, Class II hitch, Silver award at SHOklahoma Car Show
M
MeShoHorney
Guest
How bout a little more info here? Which Porche tranny would mate with the said adaptor? I would assume that ther are a lot of bits needed to make this work with the linkage.
Marcus, don't give up the farm just a bit more info
Touche on the sig. once again!
Jason
'91 Red |Pseudo + Edition|
Mods? Yeah, I got some! SHOracing.com
SHODUDE
Valdosta, GA
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
To go through 2 trannies in a month is bad. I do a few burn outs every now and then and my tranny with 130k miles is fine. I think there is more to it then just fluid. Why do your trannies go out?
92 White SHO
HiRevs Competion Clutch
SHOSHOP Engine Mounts
Koni Shocks
StrutTower Braces
UD Pullies
Awesome Sound System
Mr.Xc
Alden,N.Y. U.S.A.
To: 91shotogo...Comming from a Ford dealership parts dept background of 15 years, Ford had an oil designated for use in the SHO mtx. Ford discontinued this product about 4 years ago. The factory recomends any semi synthetic -to- full synthetic "mercon" or dexron atf fluid. (The original product was a full synthetic red atf fluid)
Tommy's SHO
SHO Member #535
Montréal, Quebec - Canada
Mr.Xc:
Interesting........What does ford recommend with the automatic transmission?
RCM
Forum Sponsor
Pennsylvania, USA
The service manuals say:
1989- Type F or Dexron II ATF
1990- Type F or Mercon ATF
1991- Mercon ATF
1992- Mercon ATF
1993- Mercon ATF
1994- Mercon ATF
1995- Mercon ATF
The specification books call for the same, but recommended synthetic Mercon in
1993 and 1995.
Russ
[email protected]
91SHO2GO:
I have a 91 Sho with a 5 speed and ive only owned it a month and went through two trannys. What Lubricant goes in these trannys? Thanx!
