blew the powerdine up today.
Revere sho
Revere MA.
SHOMurph said:
lotsa miles as Tony uses El Toro as a daily. dunno...I'll ask Tony how many tomorrow.
sorry Tim I was sworn to secretcy (sp?) Dyno sheet is locked away at his house. However he is having to reinforce a new subframe as he has tweaked the old one.
what is he doing to reinforce the tranny? And i think i already asked this awhile ago but then forgot but what is shot peening and where can i get it done? the tranny i have now is quaifed and cryo treated
gtstang1967
BannedInBoston
New Bedford,MA
i remember seeing some supercharger broken there a couple weeks ago when i bought the car from him. i dont care what kind of kit it is i am just looking for a cheap starter kit if i like the what it work i will upgrade. i saw it there on the 13th or something like that
yamahaSHO
E85 whore
Arkansas
As stupid as Vadim did some things... He had some thought into it. In the case of Pat's car, he's pretty much found out what the maximum timing he should run on a particualr setup and then added 10 degrees. Since the computer can kick back up to 10 degrees, his thought was that this might save the motor.
On single passes, this may be fine, however, when you keep stressing it, all of the above play a roll in self-destruction.
I'm not surprised the PD blew up... I remember getting into it with a forum member on here who thought that they were great blower, even if you upgrade for higher boost... Simply put... You get what you pay for.
MYSHO1
PiCkLe DaNcE!
Wakefield Ma, e.p RI
I can rebuild it for $100, im not worried its a cheap start off set up, it blows it blows Sho's are cheap in the long run and as long i can get a little more power out of it tuned right, thats all i really care about.
Mike Kopstain
Arlington Heights, IL
That's smart? Add 10 degrees over whats normally considered acceptable and let the PCM take care of the rest? You realize that in order for the PCM to retard timing it needs to sense knock? Any knock on a high compression, high boost, non-intercooled car is asking for trouble. Nothing about this kit was thought out, sorry.
SHO92
Upper Freehold, NJ
I think Jason meant that the idea was a decent one, but the execution doesn't work. Maybe it would in a perfect world.
