Anti lock brake failure ?
Kevin
Winsted,CT
I made a panic stop in the rain..60-0 and the car(91)just skid. In my 90, the pedal pulsated and the tires never locked up.Is there a common fix for no antilock ? In general the car stops ok.
T
ThatSHOkid
Guest
try the fuses? mien wasn't workign and it was a fuse. my antilock light was on for a week or 2 before i tried it and bingo they worked again.
1993 White/Tan SHO MTX 97k Miles
[*] Performance: Sho Shop Y Pipe * Coneless & Boxless * K&N Filtercharger * Superchip Performance Chip
[*] Appearance: Colgan Custom Bra * "SHO" Windshield Banner * Blacked Out "SHO" Lettering * Ventshade Sunroof Wind Deflector & Vent Guards * GTS Headlight Blackouts
[*] Audio: Sony 10 Disc Changer
[*] Lighting: Eagle Super White Headlights * American Products Company Super White Reverse & License Plate Lights * Blazertech Foglights
[*] Coming Soon: Tinted Windows, Sub Frame Connectors, Sway Bars, Front Strut Tower Braces, & A Sig Pic!
[*] The Driver: Jay/Jason/Hubes
[*] The Car: Zsa Zsa
[*] The AIM Screename: KingPin641 (a NESHOC member)
"Drive it like you stole it!"
bensho92
man, there is nothing wrong with your car, thats just the way antilock brakes work.
Shoman594
Moderator
Lockport, IL
Edited - Yes, I didn't read the post thoroughly.
If the ABS system were not functioning correctly, you should be getting an ABS warning light in the instrument cluster.
Scott
1991, 253K miles, glass hood, police grill, SVO shifter, Catz fogs,
[This message has been edited by sdpatt (edited 12-31-2001).]
[email protected]
Albany, OR - USA
Guys, re-read the post.
In his '91, the car just skidded.
In his '90, ABS operated like it should.
Kevin: is the ABS warning light on? Is the ABS pump motor running? (Listen down near the driver's side front tire for a motor)
Kevin
Winsted,CT
Thanks for your response and Happy New Year!
Why I got another SHO I'll never know but...
1)My antilock light is/never was on. I'll check the fuse anyway.
2)Hope the fix is something simple...ABS wheel sensors sounds like a Bi#!%; especially since the car is getting 4 new struts @ Sears this week and funding is getting low.
3)Thanks anyway SDATF...after 1529 posts, I'll forgive your cursory read as I'm sure you have seen enough SHO problems (I know I've seen enough w/my 90 SHO).
4)Thanks [email protected]'ll listen for the motor tommrow before I check out a possible 5.0 Mustang for my 17 year old son.
Kevin
Winsted,CT
I checked the car today and the antilock pump motor is running. The abs warning light is not on. I,m not sure where to look for a fuse for the abs? Would a bad fuse cause the warning light to come on? any thoughts before I bring it to FORD?
